Hello,
I have a G code that uses 4 fixture offsets with Y axis being the same and X axis 1.5625 from part to part. When a new offset is called and axes positions there is a pause before g code executes. If you look at video you will notice it the most at the beginning of the 2 disks in the center of vice. X and Y position for co bore and then there is a pause. Pause only happens at first hole of each disk. These 2 disks are getting a counter bore using cutter comp and then drilled thru with same tool, endmill.
https://www.youtube.com/watch?v=ccumTBjzOVcAnyone know why this pause is there? Or got any ideas?
Here is full g code.
O01001
(T1 D=0.194 CR=0. - ZMIN=-0.535 - flat end mill)
G90 G94 G17 G40
G20
G53 G0 Z0.
(2D Contour3 2)
T1 M6
S3500 M3
G54
G0 X-0.6974 Y0.9317
G43 Z0.1 H1
G1 Z0.0394 F80.
Z-0.125
G41 X-0.6314 Y0.7148 D1
G3 X-0.4146 Y0.625 I0.2169 J0.2169
G1 X0.2146F50.
X0.4146
G3 X0.6314 Y0.7148 I0. J0.3067
G1 G40 X0.6974 Y0.9317
G0 Z0.1
(2D Contour3 2)
G55
G0 X-0.6974 Y0.9317
G43 Z0.1 H1
G1 Z0.0394 F80.
Z-0.125
G1 X0.2146F50.
X0.4146
G0 Z0.1
(Bore2 3)
G56
G0 X0.563 Y0.
G43 Z0.1 H1
G1 Z0.1 F60.
G41 X0.519 Y0.122 D1
G3 X0.397 Y0. I0. J-0.122
X0.3976 Y0.0145 Z-0.0479 I0.166 J0.
X0.7288 Y-0.0072 Z-0.124 I0.1654 J-0.0145
X0.397 Y0. Z-0.2 I-0.1658 J0.0072
X0.729 I0.166 J0.
X0.397 I-0.166 J0.
X0.519 Y-0.122 I0.122 J0.
G1 G40 X0.563 Y0.
G0 Z0.18
(Drill2 3)
G0 X0.563 Y0.
Z0.1
G98 G83 X0.563 Y0. Z-0.535 R0.1 Q0.2 F30.
G80
G0 Z0.1
(Bore2 4)
G0 Z0.1
X-0.563 Y0.
G1 Z0.1 F60.
G41 X-0.6126 Y0.1164 D1
G3 X-0.729 Y0. I0. J-0.1164
X-0.7284 Y0.0145 Z-0.0479 I0.166 J0.
X-0.3972 Y-0.0072 Z-0.124 I0.1654 J-0.0145
X-0.729 Y0. Z-0.2 I-0.1658 J0.0072
X-0.397 I0.166 J0.
X-0.729 I-0.166 J0.
X-0.6126 Y-0.1164 I0.1164 J0.
G1 G40 X-0.563 Y0.
G0 Z0.18
(Drill2 4)
G0 X-0.563 Y0.
Z0.1
G98 G83 X-0.563 Y0. Z-0.535 R0.1 Q0.2 F30.
G80
G0 Z0.1
(Bore2 3)
G57
G0 X0.563 Y0.
G43 Z0.1 H1
G1 Z0.1 F60.
X0.729 I0.166 J0.
X0.397 I-0.166 J0.
G1 G40 X0.563 Y0.
G0 Z0.18
(Drill2 3)
G0 X0.563 Y0.
Z0.1
G80
G0 Z0.1
(Bore2 4)
G0 Z0.1
X-0.563 Y0.
G1 Z0.1 F60.
X-0.397 I0.166 J0.
X-0.729 I-0.166 J0.
G1 G40 X-0.563 Y0.
G0 Z0.1
(Drill2 4)
G0 X-0.563 Y0.
Z0.1
G80
G0 Z0.1
M5
M9
G53 G0 Z0.
G53 X0. Y0.
M30
Troy
